Deleting CAGS w/ LS1 Edit?
Old Oct 12, 2002 | 09:55 AM
RAGEman's Avatar
Default Deleting CAGS w/ LS1 Edit?
Is this at all possible?
TIA.
Old Oct 12, 2002 | 10:18 AM
Smoke_ur_5.0's Avatar
Default Re: Deleting CAGS w/ LS1 Edit?
Yep, go to transmission and set the mph for CAGS enable to 254 and disable at 255. There are a coule other ways to do it. You could even do 1% tps....or if you want to take the time.... find out what mph you shift into third at WOT and set the enable at that mph. This way when you go for that grandslam 4th gear powershift and accidentally go to the 2nd gear gate it blocks you out. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Oct 12, 2002 | 02:23 PM
RUF SS's Avatar
Smoke_ur_5.0,
That is a very good idea!!!
Old Oct 12, 2002 | 02:50 PM
RAGEman's Avatar
Mark, you are my new best friend (whether you like it or not), and to you I owe a lifelong debt of gratitude. That said, can you see if you can get me a free RAM clutch? Or, if not, any other clutch that's free will work.
<img border="0" alt="[pimp]" title="" src="graemlins/gr_pimp.gif" />
Old Oct 14, 2002 | 10:43 PM
TooManyIDs's Avatar
You can do this by changing one field only.
Set the coolant temperature enable from 173F to 325F.
