Help please...voltmeter pegged out at 18
Old Oct 13, 2002 | 09:43 PM
BadSS LS1's Avatar
Default Help please...voltmeter pegged out at 18
Don't know what happened, I was driving home from work, and all of a sudden the voltmeter maxed out. All of the idiot lights came on, my headlights got really bright, etc. What could be causing this? thanks....
Old Oct 13, 2002 | 09:47 PM
wrencher's Avatar
wrencher
Default Re: Help please...voltmeter pegged out at 18
Probably is the alternator, get it checked out asap.
Old Oct 14, 2002 | 01:09 PM
MIGHTYMOUSE's Avatar
check/repair replace the one red wire that goes to the alternator plug.. if it shorts or gets high resistance it will make the alternator overcharge.. i bet there is water/corrosion in the plug. check it out.
Old Nov 4, 2002 | 06:44 PM
eallanboggs's Avatar
You can try the process of elimination troubleshooting system for this problem to isolate it. You can either pull out all fuses that load the electrical system down and put them back in one at a time until the meter pegs or just pull them out one at a time until the meter drops back to the normal level. When you see the change you troubleshoot that circuit as you normally would any other electrical problem
