What is the lowest safe idle?
Ideally, you want to be able to you get your IAC count down to around 35 for the best idle. After H/C you are probably up around 95.
If you start drilling without knowing this perameter, most likely you will overshoot and end up with a car that takes forever to return to idle, or does not idle properly. Then you have the joy of epoxying your TB hole.
Drilling the TB should be done in VERY small steps.
Good Luck,
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
