resetting SES light
Old Oct 18, 2002 | 11:47 AM
ESMsilver00SS's Avatar
Default resetting SES light
what are the options for getting rid of an SES light after replacing 2 bad injectors and plugs? I'd like to find a way without having to spend more money. Does disconnecting the battery work every time?
thanks,
Eric
Old Oct 18, 2002 | 01:31 PM
NoGo's Avatar
Default Re: resetting SES light
I do alot of electrical work on my car, and having the battery disconnected for around 4 hours will clear my PCM.
There is also a method of pulling the proper fuses. I have never used it.
Maybe somebody who has done this can chime in.
Old Oct 18, 2002 | 07:05 PM
Thanks for the info. I think I might try that because my car is still running bad after I replaced two bad plugs and fuel injectors.
Old Oct 18, 2002 | 08:52 PM
phat-ss's Avatar
turn key to on but not starting car
pull the pcm and ecm battery fuse one 10 amp one 15 amp one is in each box .
turn key off wait 2 mins or so
replace fuses and start car ecm is reset
