Need help with tuning session tomorrow...
Old Oct 18, 2002 | 11:04 PM
TXNC5's Avatar
Default Need help with tuning session tomorrow...
I am getting familiar with the Ease scanner and LS1 Edit. I had a 383 kit installed, heads, big cam, headers (TPIS), upgraded fuel pump (LPE), bigger injectors (I was told they were 38# at my psi).
Just started her up tonight to make sure everything was working blah blah. I have made all the base changes, and got some help with the injector tables.
1) Do I need to drive some before scanning? How much? Time, miles?
2) The injectors seem to be noisy. I checked this with a stethoscope. I thought it was valve train, but it is definitely the injectors you can hear. Is this normal? Does someone have a spreadsheet for the values that I can compare to what ChrisB sent and/or my actual ls1 file?
3) As an example, if I scan tomorrow and LTFT's average at part throttle say +10%, then what do I do to the MAF table?
Thanks.
Old Oct 18, 2002 | 11:22 PM
99taws6's Avatar
Default Re: Need help with tuning session tomorrow...
http://ls1edit.slowcar.net/tuning.html
This should help you out for the most part.. I did all that it told me to do and it seems to have given me more SOTP power.. Sunday at the track will be the test...
