Which reluctor?
Old Feb 2, 2006 | 12:00 PM
jyeager's Avatar
Default Which reluctor?
I'm considering an aftermarket ECU to drive an LS2-based motor. I assume that the LS2 shortblock will come with a 58 tooth reluctor, but don't know if the aftermarket systems support that. I haven't even picked the aftermarket ECU yet. In consideration are FAST, GEN VII, MOTEC, BS3.
Will they all support that reluctor wheel, or should I spec a 24 tooth?
Old Feb 2, 2006 | 12:12 PM
horist's Avatar
a 2005 LS2 will have the 24 tooth reluctor and you could use that w/an LS1 PCM if you wish (companies such as thudner have the necessary conversion parts to get knock sensors and such to work w/an LS1 PCM)
if you go w/a 2006 LS2 then it's 58 tooth... I'm not very familiar w/aftermarket computers however, so not sure if any of the above can be set to correct for this
Old Feb 2, 2006 | 12:18 PM
jyeager's Avatar
Thanks. The plan is to use an aftermarket unit ECM, and run speed density for twin turbos.
