Who is using FAST on an LS1?
Is anyone using this setup on an LS1? Is it a really involved install, or is it just splicing in injector wires and other sensors.
Is the FAST system a piggyback off of the stock computer? Does it have a custom wiring harness for use with the LS1?
Thanks,
Scott
It is a stand alone system and does not piggyback.
You will be splicing into existing sensors as well as adding some more eg.3 bar map sensor for boost.
I have the system on my T-Type and am working on getting the right tune,frustrating but satisfying.
I talked to another guy that does custom installs and he said that the computer will be a 'piggyback' hybrid in cars that want to maintane the factory dash...basically the computer will stay to run the gauges and the FAST system will run the car.
I am going to give a shop called Fast Track a call...they are a dealer and they are located in Southern California.
Thanks,
Scott
