Ls1 Edit: Air Pump Coolant disable temp?
Old Oct 26, 2002 | 07:12 PM
felton316's Avatar
Default Ls1 Edit: Air Pump Coolant disable temp?
In Ls1 Edit under Engine Cal>Test Parameters, the box labeled Air Pump Coolant Disable Temp, does that value represent the temp the coolant must drop below or rise above before the air pump is disabled. I was wondering if I put some outrageous value in there, will it disable the air pump?
<small>[ October 26, 2002, 07:16 PM: Message edited by: felton316 ]</small>
Old Oct 27, 2002 | 10:40 AM
felton316's Avatar
Default Re: Ls1 Edit: Air Pump Coolant disable temp?
ttt
