Help with MAF
Old Oct 29, 2002 | 02:34 PM
Nitrous97's Avatar
Default Help with MAF
Hey I will try to make this as short as possible. I installed headers on my car. I now get a maf error code. I have changed the maf back with stock.(to see if it was the sensor). I have checked scanmaster and got no reading on MAF. It isnt the sensor itself. I was told that Maf ground wire goes on the pass side of the engine block in a bundle by the headers , when your underneath the car looking up. The abs inop light came on as well at the same time, and the brake light blinks. I was hearing a ticking noise from the engine area. The ticking noise stopped when i either held the brake down or pulled the abs fuse. The abs light with the brake light blinks while fuse is in. It stops blinking when i press brake down. Im totally baffled. I need your help guys. I cant get performance without MaF readings. I have a lot of bolt ons but all work with the comp emmisions legal. Has anybody had a problem with headers burning this bundle or setting off lights?
