Knock sensor 1 low imput?
Old Oct 31, 2002 | 10:15 AM
JASON's Avatar
Default Knock sensor 1 low imput?
anyone see this before?
Old Oct 31, 2002 | 09:18 PM
98TAauto's Avatar
Default Re: Knock sensor 1 low imput?
did you recently swap intakes or anything??
you have 2 sensors under your intake. More than likely one is loose, bad, or you have a crimped wire.
I got that code when i installed a LS6 intake.. pulled it and one of the sensors were loose and a wire may have been crimped. Put it back on and everything was fine
that sensor will pull 4 degrees of timing also when its on! Not hurting anything, just a safety thing
