Low Coolant light?
Old Nov 1, 2002 | 12:56 AM
Importdestroyer's Avatar
Default Low Coolant light?
Yeah its on but the coolant level is fine. What the hell? 41k miles. Same thing happened in my LT1 camaro. Why is this?
Old Nov 1, 2002 | 01:10 AM
98TAauto's Avatar
Default Re: Low Coolant light?
i think ive read on here in a few places that the coolant level sensor is a POS and goes bad often! More than likely it may need to be fixed or replaced
Old Nov 1, 2002 | 10:37 AM
LS1-SSS's Avatar
Before you buy a new sensor clean the old one!! Most of the time it is just a dirty sensor. This is quite common to our cars. It has happenned to me a couple of times. It is a simple job. Syphon out enough coolant to be able to disconnect sensor. A turkey baster works gtreat for this. Clean off the sensor. Put back in. Refill radiator. You're done. You may or may not want to reset/clear the code but usually it clears itself.
<small>[ November 01, 2002, 10:38 AM: Message edited by: LS1-SSS ]</small>
Old Nov 1, 2002 | 05:28 PM
felton316's Avatar
You have to buy a new one or just unplug the harness from the bad one. The light will go out either way.
Old Nov 2, 2002 | 07:29 AM
LS1-SSS's Avatar
"You have to buy a new one ..."
Why do you say that?
Old Nov 2, 2002 | 08:04 AM
cantdrv65's Avatar
my coolant was actually low, had a leaky water pump.
Old Nov 2, 2002 | 02:49 PM
Thanks for the help guys!
