EFI Live & Auto Tap Issues?
Old Nov 3, 2002 | 10:47 PM
2K1SS's Avatar
Default EFI Live & Auto Tap Issues?
I keep getting a error message that says;
You are using hardware that does not match what you registerd for. Make sure you are using hardware with the serial number ######.
There was no Registration # given for A-tap, just EFILive and I tried that one and it does not work either.
with EFILive I get;
23:42:18:480: Connected to Com1 using baud=19200 paridy=N data=8 Stop=1
23:42:18:060: Interface hardware: 'Unknown' is not supported
I have tried everything I know and cant get it to work. The EFILive Pro also will not work.
Very fustrated,
Can someone help??
Thanks!
Old Nov 4, 2002 | 08:05 AM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
Default Re: EFI Live & Auto Tap Issues?
Give them a call, they will walk you through it. They are great about that.
Old Nov 5, 2002 | 01:06 PM
2K1SS's Avatar
Thanks,
I E-mailed on Friday but I still have not got it resolved!
Old Nov 6, 2002 | 12:58 AM
Randy WS6's Avatar
I had the same problem ,did you hook it to the car first.If you don't, you will get that problem I just regestered the EFI Live while I had it hooked up to my car and the key was on .And it fixed it hope that helps
Old Nov 6, 2002 | 10:31 AM
2K1SS's Avatar
I found the trick!,
The issue was once you coppy the folder over from the update 5.26.1. You have to go in and DE-select the "read only" and I changed the Flow controle to "hardware" and it came right up!
Now just have to learn some values. The first one is a better way to get an acurate AF ratio. Mine is 14.6 & 11.9 with no inbetween!
Thanks If anyone has the same type issue E mail me and I will try and walk you through it!
Thanks
Mike
