Starting problem.
Old Nov 9, 2002 | 03:22 AM
AzzHauler's Avatar
From: Richmond, VA Where fast cars, well......are hard to come by.
Default Starting problem.
Let me know what you guys think of this:
My car starts just fine when cold (after sitting all night), and when warm. But if you let it sit for say an hour or 2, it has a tough time starting. I have to hold the starter engaged for a lot longer and when I let it go, it sputters real bad, barely firing, and once it catches, it comes to life fine. Most of the time it won't start the first try, it'll die out. Now, I didn't have this problem before I put a set of svo 42# injectors on it. But I'd think if it was the injectors, then it'd always have a problem. I have the injectors and ls1edit, and that's it relating to fuel system. My fp gauge reads the same during these startups as it does any other startup.
Any ideas?
