O2 READINGS!!!!!!!!!!!!!!!!!!!!!
Old Nov 10, 2002 | 11:34 AM
LASTLS1's Avatar
6 Second Club Moderator
Default O2 READINGS!!!!!!!!!!!!!!!!!!!!!
ED WRIGHT DID COMPUTER AND I ALREADY SENT IT BACK TO HAVE IT RICHEN UP, BUT I AM STILL GETTING O2 READINGS IN THE 840'S WITH A STOCK MOTOR! ARE 02 READINGS WORTHLESS OR IS IT POSSIBLE THE CAR IS STILL TOO LEAN! IF I SHOOT THE BOTTLE THEY GO INTO THE 700'S STOCK MOTOR , JUST FILTER,LID AND SMOOTH ELBOW!
Old Nov 10, 2002 | 11:57 AM
The Derek H's Avatar
Default Re: O2 READINGS!!!!!!!!!!!!!!!!!!!!!
O2 sensors at 14.7:1 Air Fuel Ratio should be fairly accurate but the farther you stray from that number the less accurate they are. To be in good shape I would recommend trying to dyno the car and use a wideband O2 setup to see what your true air fuel ratio is. Then you can go back and base the information off of this. Maybe someone else can give you some more help. I'm very new to tuning and don't know a lot about it but this is what I have been told.
