Tuning a stock car ('02) does help.
Old Nov 11, 2002 | 12:07 AM
GrannySShifting's Avatar
Default Tuning a stock car ('02) does help.
Put grandmama's 02 WS6 (six speed with 4800 on the Odometer) on the rollers, and it put down 315 SAE hp and 340 ft-lb (325 hp uncorrected)
11.7-12.1 A/F, 24 degrees ax timng. Leaned it out to 12.4-12.8 up to 4900 (takes a nosedose no matter what after that, looking at the graphs I know it would have peaked about 8 hp higher if it didnt) and added 3 degrees across the board, it made 325 and 350 corrected with gains of 15 lb-ft from 2500-3300.
I thinkn theres probably antoher 10 lb-ft on th etable with some more tin and fuel in the bottom plus fixing the nose dive in the A/F ratio would nd up with 330/360 SAE corrected.
