HPP3 on 02 and up opinions
Now..I am running 13.1's and 13.0's all the time. I want to run more 12's of course. Would the HPP3 benifit me enough to pick up a tenth or two?
Thanks
Kurt
<small>[ November 14, 2002, 07:51 PM: Message edited by: 02 SOM SS ]</small>
Seems the HPP3 programming is hit or miss... you either gain or you don't get anything (and sometimes it can cause the car to loose speed in 1/4 mile)
<strong>Maybe... hard to say. All the HPP3 power programming does is copy the high octane table to the low octane table and raise timing, plus it flattens the spot at peak torque where stock there's a dip (peak cylinder pressures)
Seems the HPP3 programming is hit or miss... you either gain or you don't get anything (and sometimes it can cause the car to loose speed in 1/4 mile)</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ic...does raising the shift points do much?
