LS1 Edit and shift points for A4 "please"
Old Nov 15, 2002 | 10:21 AM
turbo's Avatar
Default LS1 Edit and shift points for A4 "please"
So, I set my rev limiter. I just need to set my shifting, but I dont know how to set the mph or the 1-2 2-3 shifts.
Im trying to shift at 6400rpms and I might even go 6600rpms.
Any help would be great!
Thanks
Casey
Old Nov 16, 2002 | 12:46 AM
pekkaz's Avatar
Default Re: LS1 Edit and shift points for A4 "please"
1 ) Atap your current shift point RPMs and determine the difference to the desired.
2 ) Look into how much that RPM difference is in MPH in each gear with your gear ratio. Use for example http://www.f-body.org/gears
Adjust the WOT shift tables accordingly. If you went higher in gearing you may need to shift slightly earlier than calculated.
