LS1 Edit, changing Timing Advance?????
So I went back to the stock timing table, at WOT I have 28* timing according to ATAP with no KR.
<strong>I added 2 degrees across the board to the high octane table. I had no KR at WOT, but on the xway at 60mph and wanting to increase to 70mph with a slight push on the pass pedal (low load), I had detonation. I have not ATAPed this situation.
So I went back to the stock timing table, at WOT I have 28* timing according to ATAP with no KR.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You can help to eliminate your highway KR by reducing timing in the higher gram/cyl cell for RPMS less than 1600.
Try reducing timing from .48 and up through the 400 to 1600 rpm range, rather than knocking your entire timing table back.
Good Luck,
Kevin
Kevin.Villier@mail.state.ky.us
THANKS!!!
