Newbie HPP3 questions, sorry
Is it worth it to run HPP3 on my car? This program isn't VIN locked like ls1edit right, so I could use a friend's copy?
The reason I ask is that I'm getting 160 thermostat soon. I figure the car would run in open loop mode (or closed, whatever the warm up mode is called), and I have been told this too. The HPP3 would take care of that.
I plan on getting a copy of LS1edit in the future, but it is not needed now.
also the hypertech can only be used on one car at a time if your friend returns his to stock then you can use it but for him to use it again you would have to return yours to stock
<small>[ November 17, 2002, 04:16 PM: Message edited by: ChrisWS9 ]</small>
With Predator will I need Autotap or the likes? It looks like its worth the extra money over hyperjunk. If I go with this program, will I still need the thermostat, or could I just lower the temperature for the fan turn on?
low speed on at 180
off at 175
high speed on at 195
off at 181
hope this helps
