OBD-II connector Pinouts
Old Nov 17, 2002 | 04:08 PM
01 Silverado's Avatar
Default OBD-II connector Pinouts
On the ECM connector... for a 2001 Silverado, does anyone have the diagram for what each pinout does?? Me and a friend are fabbing up a connector for it, and need to know what each pinout is.
thanks!
-Kurt
Old Nov 17, 2002 | 05:07 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
Default Re: OBD-II connector Pinouts
I don't know how many other terminals may be used on an 01 truck, but what is needed for PCM communication are:
pin 2 serial data
pin 4 ground
pin 5 ground
pin 16 battery voltage
There maybe other pins used for other modules (ABS, Air Bag, etc.) but those are the PCM pins.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Nov 17, 2002 | 05:38 PM
There are 5 terminals with the pins... does anyone know what the 5th could be? thanks!
Old Nov 17, 2002 | 07:50 PM
EFILive's Avatar
Restricted User
http://www.starrperformance.com.au/e...OBDIIconnector
Old Nov 17, 2002 | 10:33 PM
Magnus's Avatar
LS1TECH Sponsor
I belive pin 9 also goes to the PCM however I haven't figured out what its for.. Some UART connection of sorts..
Paul, you know?
Check out the OBD Hacking Board tommorow (Monday). I have another set of work bench pictures going up including pics of my ghetto-fab off-board programming adapter for the tech-2.
- Keith
Old Nov 17, 2002 | 11:32 PM
EFILive's Avatar
Restricted User
Hi Keith,
Yes, some OBD-II equipped vehicles have a hybrid system where the PCM is OBDII and the other modules in the vehicle are pre-OBDII, 8192 baud UART. The vehicle will typically have a PIM (Powertrain Interface Module) that converts the OBDII to 8192 UART and back again to facilitate comms between the two different systems.
The OBD-II connector uses pin 9 to provide access to the 8192 UART data of the non-OBDII modules.
Regards
Paul
Old Nov 18, 2002 | 07:16 AM
Speartech's Avatar
I don't believe pin 9 goes to the PCM on an 01 truck. I think it's the airbag uart serial data line. Just airbag, not PCM.
__________________
www.speartech.com
