I found the problem...how to fix it?
Old Nov 18, 2002 | 09:51 PM
Poltergeist's Avatar
Default Re: I found the problem...how to fix it?
Did you edit out the rears O2s, use SIMS or nothing?
Old Nov 18, 2002 | 10:21 PM
Unleashed's Avatar
It wasnt' what I thought it was.....when I was putting the headers on, the shop was going to close soon. I got hurried and hooked up the front O2's to the rear plugs <img border="0" title="" alt="[Sad]" src="gr_sad.gif" /> , that would probably explain my problem. I will be deleting the O2 sensors later this week when the LS1 Edit software arrives! Now I have to cut and splice the wires to extend them. I did learn alot about O2's in the process of realizing that I screwed up! <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 18, 2002 | 10:59 PM
NastyWS6's Avatar
Kinda wierd, I was experiencing the exact same problem when I logged a run this weekend, but I have all my connections right. Anyone able to help figure that one out ???
Old Nov 19, 2002 | 12:57 AM
Unleashed's Avatar
Default I found the problem...how to fix it?
EFI Live is showing that my O2 sensors are staying in the "Open Loop-Fault". I just put on SLP LT's and only hooked up the front two. Does this mean that the O2 sensors are bad? Is there anything to look for before just buying new ones? Thanks.
