WB keeps overheating?!?!
Old Feb 7, 2006 | 07:16 PM
bowtieman81's Avatar
Originally Posted by WS6FirebirdTA00
thing is i hate having it that far back, the response time in low rpm for it to adjust to the AFR is too long for me, i get off teh gas then back on then see it go rich when it really goes rich when i am off the gas, i dont want to have it so far back for tuning that the readings are time delayed. when i say it over heats, the led flashes at me and it reads constant 11.0:1, it has done this 3 times to me, with so many people not having issues i wonder ifits my sensor?
Hey, I have the same problem. Not sure if it lights up the LED or not, but mine will work fine, then all the sudden read a constant 11:1 no matter what driving conditions. I already replaced my sensor at innovate's advice. Didn't fix it. Next up is the controller.
Old Feb 7, 2006 | 07:18 PM
WS6FirebirdTA00's Avatar
at this rate i am going to have to route my cooling system to it lol
Old Feb 7, 2006 | 07:19 PM
i wonder if i shoudl make that shied that i saw in their cd?
Old Feb 7, 2006 | 07:21 PM
oange ss's Avatar
where is the sensor at on the pipe exactly ?
Old Feb 7, 2006 | 07:48 PM
mr2guru's Avatar
Why not build/install a heat sink per the LC-1's directions?
2.3 How to fabricate a copper heat sink
Use a 4” x 4” (10cm x 10 cm) sheet of copper sheet metal 14ga (1.5mm) thick. Drill a hole in the center with the same diameter of the oxygen sensor threads ~3/4” (19mm).
Fold the sides up 45 deg and mount it between the sensor and the bung like you would a big washer. Orient it such that the sides are exposed to good airflow.
Old Feb 7, 2006 | 08:13 PM
that is what i am talking about.
the bung is located in the 10/11 oclock position on the leg of the drivers side ypipe that goes to the y collector. it is 2/3 of the way toward the merge
Old Feb 7, 2006 | 08:14 PM
wonder where a good place to get copper would be...
Old Feb 7, 2006 | 09:06 PM
oange ss's Avatar
any hardware stor should have small sheets, is the sensor on the backside of the pipe ?
Old Feb 7, 2006 | 09:09 PM
no the front
Old Feb 7, 2006 | 09:17 PM
oange ss's Avatar
so most of the transmission is blockin airflow around the sensor I would imagine......
Old Feb 7, 2006 | 09:21 PM
its out to the side of the tranny but when i put that heat shield on there i will double check, if not ill make a better shield to scoop it up some more
Old Feb 7, 2006 | 09:29 PM
  #32
oange ss's Avatar
believe it or not the fatotry air dam will channel alot of air to the radiator but push the rest out of the way, then you got the motor, suspension, etc...
Old Feb 7, 2006 | 09:36 PM
  #33
maybe i shoudl cut a hole in my floor board and stick my hand down there and feel for air lol. im hoping that heat sink deal will stop this crap lol
Old Feb 7, 2006 | 09:40 PM
  #34
oange ss's Avatar
i think your cooling system idea is more feasable
Old Mar 5, 2006 | 11:42 AM
  #35
00Z28SS's Avatar
Let me know how the heat sink works. I am having the same problem with overheating. The dreaded E-8 code. I have a heads/cam car and it never overheated until I started spraying nitrous. It's really pissing me off because I cant read my air/fuel during nitrous use and that's when I need it the most!
Old Mar 5, 2006 | 02:03 PM
  #36
well the heat sink didnt work, looks like ill have to get the expensive one...
Old Mar 5, 2006 | 09:45 PM
  #37
SmokingWS6's Avatar
I cant believe it would actually be overheating in that location, especially considering the mods and afr. Perhaps there's a malfunction in the heater control circuit or something along those lines. fwiw, i've used mine in the summer heat located in the collecter and it never popped up any codes.
Old Mar 5, 2006 | 10:24 PM
  #38
DanaliHD's Avatar
mine is doing the same thing. I tried recalibrating it using it but it didn't help. I tried ordering a new one yesterday but Innovates website was messed up. I guess I'll try again tomorrow
Old Mar 6, 2006 | 09:02 AM
  #39
MeentSS02's Avatar
Kleeborp the Moderator™
Although I don't have the heating issue all the time, my HBX-1 should be here today, so I'll give it a try and see how it works.
Old Mar 6, 2006 | 11:00 AM
  #40
DO NOT ORDER FROM INNOVATE
you can get them for about 38 bucks from VW I am ordering a new one right now
