Stuck in WOT?
If this happened after an N2 backfire, then I would start looking for hoses that may have gotten blown off in the melee.
I would check
1) Brake booster hose
2) MAP Sensor. May have blown off reading 0 MAP which could be conscrewed as WOT by the PCM
3) Throttle Body.
4) EGR
5) Air Relief Hose to Throttle Body
6) PCV Hose to Throttle Body
7) Intake Seal. You may have cracked the intake or blown a seal out.
Good Luck,
Kevin
<strong>
3) Throttle Body.
4) EGR
Thanks for all the info (-:
Good Luck,
Kevin</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">1. the bosster hose is broke but I taped it.
2. map sensor is still in. I can see it through the intake manufold.
3. I am going to test the tps tonight.
4. will test it tonight also.
5. is fine.
6. is fine.
7. I have the Hollie intake and it seems fine. I think? This will be the last thing I test.
<small>[ November 21, 2002, 11:00 AM: Message edited by: KLX300r ]</small>
