I think i am confused.....
Old Nov 21, 2002 | 11:15 AM
Boo Yeah's Avatar
Default I think i am confused.....
I am thinking of getting ls1-edit for when i install my headers.....
bu now i see that there is autotap efilive??? What is this?? Is this a computer tuning program as well???
It says...
"Idle speed - Sets the idle speed to an rpm value in the range 0-2040 rpm.
IAC - Sets the idle air control pintle position to a step value in the range 0-127
Gear - Sets and holds the currently selected gear to one of
First
Second
Third
Drive
Injector Off - Allows the operator to perform an injector balance test by selectively turning off individual injectors. Only one injector will be turned off at any time.
Switches
M.I.L. - Illuminates the Malfunction Indicator Lamp. This feature is not available on some vehicles.
Shift skip - Illuminates the Shift Skip lamp where fitted. This feature is not available on some vehicles.
CC inhibit - Inhibits the cruise control from operating.
A/C clutch - Turns the Air Conditioner compressor clutch on or off.
Fan 1 - Turns on low speed thermo electric engine fan(s).
Fan 2 - Turns on high speed thermo electric engine fan(s).
Lift/Dive - Turns Lift/Dive compensation on or off.
A.I.R. sol - Turns the Air Injection Reaction solenoid on or off.
A.I.R. pump - Turns the Air Injection Reaction pump on or off.
Fuel pump - Turns the fuel pump on or off.
Fuel learn - Turns fuel learn mode on or off.
Closed loop - Sets fuel mode to open or closed loop.
Rev lockout - Turns reverse lockout on or off - manual gearboxes only.
TCC - Engages or disengages the Torque Converter Clutch - automatic gearboxes only.
Modes
Use spark map - Overrides the PCM's normal spark advance by substituting the values found in the currently loaded spark map.
Use fuel map - Overrides the PCM's normal air fuel ratio by substituting the values found in the currently loaded fuel map.
Evap service bay test - Puts the PCM into a mode that allows evaporative emission controls to be tested.
Fuel trim reset - Resets the learned fuel trims.
Tooth error learn mode - Puts the PCM into a mode where it can learn the crank tooth error correction "
It seems to me that it tunes like edit..... AM I wrong....
Old Nov 21, 2002 | 11:37 AM
Predator's Avatar
Default Re: I think i am confused.....
The changes that EFLive can make are temporary for testing purposes. If you wanted to make any of those changes permanent, you'd need an editor, also, such as LS1 Edit.
Old Nov 21, 2002 | 11:39 AM
Boo Yeah's Avatar
thankyou i couldn't figure out why no one used it but now iget it..
THANKS <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Nov 21, 2002 | 01:42 PM
BullSSeye's Avatar
Or you can get a Predator that lets you tune your car and gives you real time diagnostic data. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
Old Nov 22, 2002 | 11:07 AM
Predator's Avatar
There's only ONE Predator, BullSSeye, and that's me <img border="0" alt="[guns]" title="" src="graemlins/gr_guns.gif" /> , and don't you forget it either. Lots of imitators out there though <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> .
