I need LS1 edit!!!!!!!!!!!
you need a laptop, probably 150mhz minimum, may be able to squeeze by with less
you need a serial port
software is easy to use, hard part is learning what to adjust to do what. Easily remedied by reading through the posts in this section. Many common items are discussed alot in here
