How to lean the car out while cruising?
Old Nov 26, 2002 | 10:19 AM
Phil99vette's Avatar
7 Second Club
Default How to lean the car out while cruising?
My LTFT are way out of wack and I need to lean the car out. Should I use the MAF table or the injector flow rate table? ANy benefits of either? <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Phillip
Old Nov 26, 2002 | 10:47 AM
NoGo's Avatar
Default Re: How to lean the car out while cruising?
I would go with the injector flow table. There are fewer complications with the adjustments.
You will probably need to re-adjust you WOT fueling after your changes. It would be best to slap the thing on a wideband and check your a/f
Good Luck,
Kevin
Old Nov 27, 2002 | 12:10 AM
7 Second Club
Would I multiply the table by 95% or by 105% to lean it out?
Phillip
Old Nov 27, 2002 | 12:17 AM
NoGo's Avatar
The injector flow table is the inverse of what you would think.
Raising the table decrease fueling.
Lowering the table increases fueling.
Your LTerms are negative, so you will need to raise the table to get them closer to zero.
