predator question
Old Nov 26, 2002 | 08:06 PM
silver02ws6's Avatar
Default predator question
ok here is my delima i have a predator the problem is i am not 100% certain on how to read what my a/f ratio is with it. i know it will do this but am not sure how nor what my a/f ratio needs to be at. any help with this would be appreciated.
Old Nov 26, 2002 | 08:46 PM
VSGLS1's Avatar
Default Re: predator question
I myself got the preditor this evening...I will really have to play around this weekend with it. What mods do you have? It will help to gauge your A/F. It should be somwhere around 13 and lower... I believe you derive the A/F from the LTFT's @ WOT....
Old Nov 27, 2002 | 07:26 AM
i have all the basic mods , air lid, maf , air temp mod, cat back, hooker long tubes and ory, and the base predator tune. the reason im asking is because after the header install its running a little rich so i want to lean it back out but want to be safe in doing so.
Old Nov 27, 2002 | 10:53 AM
seabringz's Avatar
if your running rich, add some timing and it will lean you out a little
Old Nov 27, 2002 | 01:20 PM
i was under the under the impresion that to much timming can hurt your car as well as running to lean.
Old Nov 28, 2002 | 12:08 AM
YUKONTURTLE's Avatar
I increased mine 5%. You can try it in intervals 2.5%, 5%, 7% etc. and go from there.
