MAF flatline at high Hz
Turned off some codes. Bumped up speed limiter, etc.
Now we get to scaling the MAF. Ltrims were maxed at 25. So first time we multipled the whole table by 109%, that pulled them down some. Next we scaled the table by 105%, got them down even better. Now they are averaging around +5.
Should I worry about getting them negative? If so, this would be an issue because if I go to scale the MAF anymore it maxes out in the upper Hz range at like 507.28, so my question is, is this a problem? Should I not even worry about trying to get the Ltrims any lower?
J.
