396 Lt-1 36# injector offset ?
Many people use the stock offset with good luck.
With 36's you should be able to get to your desired results by simply scaling the injector flow rate table to get your LTerms under control, then modify your PE vs RPM table for WOT fueling.
If you are hellbent on changing your injector offset table though, email me, and I will send you an offset that works well with the SVO's (gets ride of the off-throttle rich condition).
