Bigger injectors
Old Dec 8, 2002 | 06:51 PM
LS1astro's Avatar
Default Bigger injectors
How big of injectors can you run without tuning for them. Can you put in bigger injectors to run alittle richer at WOT then count on O2 feedback to lean cruise out? Or do your LTrims lean out WOT with the cruise also.
Old Dec 8, 2002 | 07:04 PM
XLR8NSS's Avatar
Adkoonerstrator
Default Re: Bigger injectors
Positive Ltrims will add fuel at WOT. Negative Ltrims will NOT take away fuel at WOT.
You might be able to do this with some SVO 30#er's(~25% bigger than 28#injectors) but, they would probably have the Ltrims maxed at -25%. If you get a MAFT you could help the stock computer out a little.
John
<small>[ December 08, 2002, 07:05 PM: Message edited by: XLR8NSS ]</small>
Old Dec 8, 2002 | 07:40 PM
LS1astro's Avatar
So perfect it will just lean it out at part throtle and cruise but at WOT it wont. I just wanted to run rich right when I finish my turbo install to keep it safe untill I get a proper tune.
