LS1Edit - Electronic Throttle Limiter Function?
Old Dec 9, 2002 | 11:15 PM
C5 Tweaker's Avatar
Default LS1Edit - Electronic Throttle Limiter Function?
I set the Electronic Throttle Limiter to 200 from 255. I expected to see a reduction in the amount that the throttle opens, but SOTP indicates it is probably still opening to 100%
I am trying to set a "Dealer Mode" for reduced power. Any input?
Old Dec 11, 2002 | 06:14 PM
C5 Tweaker's Avatar
Default Re: LS1Edit - Electronic Throttle Limiter Function?
Anyone? <img border="0" alt="[Banging Head]" title="" src="graemlins/gr_banghead.gif" />
Old Dec 11, 2002 | 08:22 PM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
If you are talking LS1 Edit, you are probably looking at MPH, not throttle opening. Pull the rev limiters way back, or the MPH WAY down.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
Old Dec 12, 2002 | 07:31 PM
C5 Tweaker's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">If you are talking LS1 Edit, you are probably looking at MPH, not throttle opening. </font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">LS1Edit has limiter options for both Throttle and MPH. Each is set at 255 stock.
Old Dec 12, 2002 | 08:46 PM
Speartech's Avatar
I think you are looking under the SPEED LIMITER tab. It is refering to SPEED in MPH.
Originally there was only the one window for speed limit as it applied to cable operated throttles. The Corvette feature was added later, so it was named "Electronic Throttle".
If you have cable throttle you make changes in the "speed limit" window; if you have ETC you make changes in the "Electronic Throttle" window.
John
__________________
www.speartech.com
