"fast data packets"???
Old Dec 10, 2002 | 02:22 AM
1dirtyZ's Avatar
Default "fast data packets"???
on an EASE diag. scan tool, there is a setting where you could stop/ disable fast data packets, should i use this to get more sampling?
what else can i do to get more samples per sec.??
<small>[ December 10, 2002, 02:22 AM: Message edited by: 1dirtyZ ]</small>
Old Dec 10, 2002 | 08:28 AM
Richard@WCCH's Avatar
Default Re: "fast data packets"???
Check the baud rate on your comm port. By default, windows sets this to 9600bps. Set the rate to max. It made a difference on my little 366mhz laptop. <img border="0" alt="[Burnout]" title="" src="graemlins/burnout.gif" />
Good luck,
Richard <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Dec 10, 2002 | 11:10 AM
1dirtyZ's Avatar
thanks headbam! i'll check that today. any other suggestions?
Old Dec 10, 2002 | 11:14 AM
Team ZR-1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 1dirtyZ:
<strong>on an EASE diag. scan tool, there is a setting where you could stop/ disable fast data packets, should i use this to get more sampling?
what else can i do to get more samples per sec.??</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Yes turn FP on, also
1. via options turn off scanner from requesting if there is DTCs during recording or realtime graphs this gives more bandwidth of connection to requesting for PID info.
2. configure RS232 for a higher baud rate
3. hit advanced and make sure receive buffers are set high.
Old Dec 10, 2002 | 11:57 AM
1dirtyZ's Avatar
thanks john!
how can i access the baud rate settings?
i also clicked on advanced and all i got is recording size and free disk space, where can i access the recive buffers option?
<small>[ December 10, 2002, 11:58 AM: Message edited by: 1dirtyZ ]</small>
Old Dec 10, 2002 | 01:37 PM
Black LS1 T/A's Avatar
Moderator
|Device Manager
--| Ports
----| Com1 (or whatever you use)
------| (Right Click) Properties
--------| Port Setting
--------| Advanced...
Old Dec 11, 2002 | 03:41 PM
1dirtyZ's Avatar
thanks black ls1 t/a ,
i found the port thingy , and i did find the bits per second setting ( not in the advanced tab)and it was set to 9600 . i tried to increase it to the max of 128000 but it keeps reverting to the 9600 setting???
i checked the advanced tab and all it had "recive buffer ( set to max) and recive buffer (also set to max)
what should i do?
<small>[ December 11, 2002, 03:44 PM: Message edited by: 1dirtyZ ]</small>
