Setting Rev limiter with preditor...
Also, how do you eliminate CAGS?
<small>[ December 10, 2002, 07:42 PM: Message edited by: HeritageLS1 ]</small>
As for the rev limiter settings, you need to switch ALL the 1-6 ON and 1-6 OFF to the same exact settings. Go into "Tune It, Modify Parameters", and then select "Rev Limiter", then go through each of them 1 at a time and adjust them up.
If you are unable to adjust the 1-6 OFF, please email me at bfb@runninwiththedevil.com, with your VIN#, along with year, makem, model, tranny, and what exactly you are experiencing, and I will steer you in the right direction so we can see where your problem is and what we may need to do on our end to fix it.
Sincerely...
