How to determine SES codes?
Old Dec 11, 2002 | 05:20 PM
zdawg28's Avatar
Default How to determine SES codes?
I picked up the car from the dealer today (had a clutch installed) and before i got home the SES light started flashing. Is there some way i can check what code it is without having AutoTap?
Old Dec 12, 2002 | 09:49 AM
eallanboggs's Avatar
Default Re: How to determine SES codes?
It's called an OBDII scan tool or drive to Auto Zone. Flashing lite means damage to cats is on the way.
Old Dec 17, 2002 | 01:14 PM
unit213's Avatar
Administrator
Autozone will do it for free. They'll clear the code too if you ask, even though they aren't supposed to.
Old Dec 17, 2002 | 05:36 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
A flashing SES is -usually- because of an ignition problem. -most likely plugs/wires.
Suggestions about having the codes pulled are good. I would go over all the coil/plug connections, then go have the codes pulled AND reset.
BOL.
