Best way to add timing across the rev range on Edit?
Old Dec 16, 2002 | 03:22 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Best way to add timing across the rev range on Edit?
My car seams to like +3 degrees across the rev range with The Timing tuner.So what should I change in edit to get this affect?To me it looks like the High octain timing table??
Car- 01 TA M6
Old Dec 16, 2002 | 04:53 PM
Lady Redhawk's Avatar
From: sojourning....looking for my city whose builder and maker is God.
Default Re: Best way to add timing across the rev range on Edit?
If you always run high octane gas, then change the low octane table to match the high. And yes to your question add 3 to all values in both tables.
Old Dec 16, 2002 | 06:43 PM
Slowhawk's Avatar
LS1Tech Sponsor
So it would be safer to just add 3 degrees in the lower too,incase I get some bad fuel.I always run 93 or 94 octain.
Old Dec 16, 2002 | 09:05 PM
thechef's Avatar
Moderator
find NoGo on hrer he is a absolute wiz with edit he can tell you <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
Old Dec 17, 2002 | 03:54 PM
Nickn20's Avatar
.6 g/cyl to about .9 g/cyl for a NA car 3000- redline add 3 degrees on that table, that should get you started, confirm with autotap.
Old Dec 17, 2002 | 09:02 PM
NoGo's Avatar
Adding 3 degrees to your High Octane Ignition Advance table will do the trick.
.6 to .9 will just cover most of your WOT.
If you want to get your part-throttle timing as well, just bump the entire table up by 3.
There are some pitfalls to this though.
a. Increase of 6th cruising KR
b. Maybe KR at peak torque.
These can easily be compensated though on the timing table if you run into it.
Good Luck,
Kevin
Old Dec 17, 2002 | 10:48 PM
Slowhawk's Avatar
LS1Tech Sponsor
Thanks for the info <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" /> I'm doing minor tuning now since I've only had it for a week.Soon I'll do the whole system when I'm happy with the hard parts on the motor <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
