lterms
Old Dec 23, 2002 | 06:19 PM
mike02ss's Avatar
Default lterms
If cruising lterms are at +5 and at wide open are at the same should I adjust base on maft to try to get to zero or should I leave it at that? Right now maft is at 0 base setting. Wot O2s are anywhere between 910 and 940.
Old Dec 23, 2002 | 11:52 PM
ChrisV 02 - Z28's Avatar
Default Re: lterms
From what i hear about the MAFT, you will want to add 5% on the bast to lower your LTFT down to 0. That way at WOT you wont be dumping additonal fuel on top of the Enrichment table.
I believe you get the base set for part throttle set first (LTFT = 0), then adjust the wot setting on MAFT to fine tune A/F
