02 Question
O2's aren't dead on accurate. They are very dependant on exhaust flow and location.
If you look under your car you will see that the O2's are not in the same place on either side, and the exhaust structure on either side is different. This can cause some variance in your O2 readings. This difference due to exhaust flow / location becomes more apparent when you start pulling CATs and putting on LT's.
Your car is fine. All your readings look normal.
