Header bang and false knock
If you don't have a scan tool, another tell-tale of KR on the dyno is a very jagged torque / HP curve, or a sudden dip of ~5 HP in power.
Asian hooker <img border="0" alt="[jester]" title="" src="graemlins/gr_jest.gif" />
and now the boring stuff.....
False knock from your exhaust is either there or it isn't..... Your exhaust has to actually resonate against the frame at such a frequency that the PCM can percieve it as false knock. The PCM knows when each cylinder fires, so it has to recieve a "thump" at such a time and at such a frequency so as to percieve it as knock.
With that in mind, it isn't how loud your headers have to hit the floor before they cause KR, but rather whether it is going to do it or not. If you are one of those unlucky souls where the exhaust is rattling against your car at just the right frequency, then it hardly needs to touch the car at all to cause KR.
Good Luck,
Kevin
