timing table questions
.2 to .4 - Normal around town to spirited driving
.4 to .5 - Sprited driving
.6+ - Very sprited to WOT driving.
Some spots to pay attention to:
Lower Left Corner - Low RPM, High G/cyl. This should be left at the stock values.
.6+ @ 4500 rpm - This is peak torque, and timing should be added very gingerly (don't increase it as much as you would your WOT timing) to avoid KR on your WOT runs.
Good Luck,
Kevin
I was seeing 26.5 degrees timing stock. I raised it 2 degrees above that and then another 2 degrees. Seemed to make a little difference in trap speed but not much. What is everyone's opinion on the best timing advance setting for WOT for these '01s and '02s?
Total advance is very car specific. It depends on octane, compression, cam, exhaust, squish, temperature, sparkplug, and combustion chamber condition.
FWIW, most cars I can get away with ~30 deg with good gas.
Some people claim that timing after a certain point doesn't increase peak HP. This is true, but it will level off your peak HP more and do as you observed, generate better trap speeds.
Good Luck,
Kevin
The engine is internally stock.
It has TR-6 plugs which are cooler than stock.
It has headers with no cats (no cats helps these cars not to have KR more than most folks would believe.)
I run a 160 thermo with very cool fan settings.
93 octane gas
So, let's assume for a minute that detonation, and therefor KR, is not a concern. How high is too high? My opinion is that going from 26-28 degrees helps noticable. Going from 28-30 doesn't hurt and may help just a tinsy bit. Going higher than 31 may actually hurt power.
Now these observation were made through extensive track testing with my '00 Z28. I don't know if they hold true for my '02 but I don't see why they wouldn't. Initial track testing tends to point that way as well.
Thoughts?
Unless it is a race application, then we go the extra mile to find out what the optimal timing of the engine is. Which coincidentally has to be done at the track under race conditions. <img border="0" title="" alt="[Cool]" src="gr_images/icons/cool.gif" />
I agree with you on timing for your setup. Colder plugs throw the KR limit up. For nitrous setups with a split timing system (IAT relay, MSD system, whatever) I stop timing at 30-31 since the cold plug throws things out of whack.
It is interesting to see two sides come to the same conclusion. Me on the dyno and behind a calculator, and you out at the track.
For your setup, I would have set timing at 28 (because you have no KR detection) and called it a day.
