How are you A4 guys checking KR
Base tune
+25 pressure
-25 shift time
1-2 +1mph
2-3 +1mph
timing set at the full 10%
power enrichment -2.5%
At part throttle in OD cruising I get anywhere from 1-3 deg retard if I lay into the throttle with the converter locked,Im pretty sure this is normal.
If I drive in 3rd and peform the same manuver I get 0-.2-.3 at the most. Since the Predator tunes at WOT these results look pretty good.
My question is should I only test and tune in 3rd gear only for the most accurate results (at the dragstrip runs are usually made in 3rd anyways).
By looking at my results do you think I could lean it out a bit more? The engine seems to run super smooth at WOT on the highway.
Thanks, Chris
Den
