Why doesnt the SES code translator work??!?!??!
Old Jan 21, 2003 | 11:13 PM
andy98Z's Avatar
Default Why doesnt the SES code translator work??!?!??!
I need to look up some codes!
0230
0740
1860
Old Jan 22, 2003 | 09:00 AM
burbanman's Avatar
Default Re: Why doesnt the SES code translator work??!?!??!
looks like the host site is down......I know the cam specs site has been down a couple of days.....
i dont know for sure why.......maybe one of the mods will know more......
good luck!
Old Jan 22, 2003 | 09:25 AM
2000WhiteZ28's Avatar
0230 fuel pump relay circuit - check your wiring
0740 TCC enable solenoid - check your wiring
1860 TCC PWM solenoid - check your wiring
Replace a transmission did ya?
Old Jan 22, 2003 | 01:27 PM
andy98Z's Avatar
Yea swapped TC's multiple times.
Old Jan 23, 2003 | 02:31 PM
andy98Z's Avatar
However that was months ago. Anyway...the light came on, on the freeway, and the light went today on the freeway.
Old Jan 23, 2003 | 02:52 PM
If it goes away or you can delete it and it doesn't come back, don't worry much about it. It could just be a aftermarket TC is causing some sensor to have a low reading.
Old Jan 24, 2003 | 08:56 AM
andy98Z's Avatar
Alright. The Z is stock now though.
Old Jan 24, 2003 | 03:26 PM
eallanboggs's Avatar
Let's see? Mich. Does it snow in Mich. in January? Do they put salt on the roads after it snows? Now we have snow, salt, slush and a trans that went in and out multiple times? Do we have a loose connector here? Probably. Then add a healthy does of salt melted slushy snow and intermittent electrical problems are bound to ocurr. When you have those kind of problems look for a loose connection or a bare wire touching ground (bare metal surface).
 Michael S. Palmer
