Should i worry {lean}
Old Jan 23, 2003 | 04:39 PM
roadrunner-r's Avatar
Default Should i worry {lean}
I have diablo ,and its hard to get a good reading.A guy here told me to look at the LTFt at 1400 curzing speed ,and they should be 0.00. There not,but at WOT the ST is o.oo
LT is o.oo sometimes 3.00 then 0
ST is o.oo
LT is 3-5 then 0.00
<img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Jan 23, 2003 | 04:46 PM
Tim Sloper's Avatar
Default Re: Should i worry {lean}
LTrims do not indicate if your car is running lean or rich. They only indicate that the PCM must deliver more or less fuel than the stock calibration calls for. That may sound like I'm saying the same thing but I'm not.
The only accurate way to know if the car is richer or leaner than desired it to use a wideband O2 sensor. Unless you have the ability to change the PCM calibrations (ie. tuning) shooting for 0 is not necessarily a good thing. If you are at 3% the car needs more fuel than GM intended and it is doing its job. There are reasons for shooting for 0 or a negative value but that assumes you can change either the MAF tables or the IFR tables.
Tim
Old Jan 23, 2003 | 05:24 PM
Iam not seeing any KR so i shouldnt be lean right?
Old Jan 23, 2003 | 05:32 PM
Tim Sloper's Avatar
I've had two cars (very minor mods) on the dyno with predator tuning and both have exhibited very poor A/F ratio curves at WOT. They would start extremely lean and get very rich at the top end. I wouldn't worry too much. If you really want to verify just throw it up on the dyno for a pull or two.
Tim
Old Jan 23, 2003 | 08:55 PM
Will do,next week thanx for help.
