Blipping the throttle
Old Feb 25, 2006 | 07:08 AM
HavATampa's Avatar
In neutral coming to a stop. It's minor really, not like it's going to die or anything. I won't be able to mess with it until next weekend, but will look into that decay table. Thanks!
Old Feb 25, 2006 | 08:50 AM
WS6FirebirdTA00's Avatar
how far does it go below the deisred idle? when mine did that putting those 0 values in the throttel cracker helped mine out. you may want to do a cold start idle airflow log, you may need to adjust the idle air.
Old Feb 25, 2006 | 12:41 PM
HavATampa's Avatar
It comes down a little to far when in neutral coming to a stop. Not a big deal and not like it's trying to die either. Just drops a hundred rpm's or so below my set rpm for about a second or two. I will play with the decay tables in neutral to see what happens.
