Removing AIR with no codes?
Old Jan 27, 2003 | 04:03 PM
FAST LS1's Avatar
Default Removing AIR with no codes?
With all the talk of removing the AIR tubes and pump, I was wondering if I could do it without throwing a code?
I got rid of my cats when I got the LT's and have the simulators in their place. Will I still throw a code if I take out all the AIR stuff and use block off plates for just the AIR tubes?
Old Jan 27, 2003 | 04:55 PM
WILWAXU's Avatar
Default Re: Removing AIR with no codes?
Some don't throw a light.. but most do.
Old Jan 27, 2003 | 06:08 PM
ROB'S SS's Avatar
ive only thrown the code(P0410)twice in the 5-6000 miles my pump has been off. i think the 01-02 cars dont throw the code as often for some reason
Old Jan 27, 2003 | 06:26 PM
FAST LS1's Avatar
What does the code that it throws when you don't have the pump hooked up say?
Old Jan 27, 2003 | 08:20 PM
SSTYCOON's Avatar
when i had my 98, i threw a code everytime @ WOT with AIR block off plates
Old Jan 27, 2003 | 08:33 PM
ROB'S SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FAST LS1:
<strong> What does the code that it throws when you don't have the pump hooked up say? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">from the ls1tech code translator section
"Secondary Air Injection (AIR) System"
Old Jan 27, 2003 | 08:44 PM
wrencher's Avatar
wrencher
LS1 EDIT can delete ses light illumination on whatever codes are deleted. But you wont pass a readiness test (for emissions obd-II tests).
Old Jan 27, 2003 | 10:37 PM
FAST LS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ROB'S SS:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by FAST LS1:
"Secondary Air Injection (AIR) System" </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm, I wonder if it's sensing that the pump isn't working, or if the O2 sensors are sensing that air isn't being injected into the exhaust? My friend is an EE, so I think we could figure out a way to trick the computer into thinking the pump is still there if it's just detecting that the pump isn't working.
Old Jan 27, 2003 | 10:44 PM
NX†C's Avatar
it will throw a code which i believe to be P0140. will usually occur about 100-300 miles after disconnecting the pump from its wiring harness. again as said you can utilize LS1EDIT to delete the code but it will receive a flag from the OBDII emission testing simulation as not being ready.
Old Jan 27, 2003 | 10:48 PM
FAST LS1's Avatar
We don't have any emissions testing here in TN so it's of no concern to me <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> I would however like to get rid or the AIR and EGR possibly without getting LS1Edit, or getting them programed out of the computer. If it's possible to trick the computer like using O2 sims on the rear O2 sensors, I'd like to explore that possibility.
Old Jan 29, 2003 | 10:09 AM
ROB'S SS's Avatar
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by ROB'S SS:
"Secondary Air Injection (AIR) System" </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Hmmm, I wonder if it's sensing that the pump isn't working, or if the O2 sensors are sensing that air isn't being injected into the exhaust? My friend is an EE, so I think we could figure out a way to trick the computer into thinking the pump is still there if it's just detecting that the pump isn't working. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">im going to guess the o2 sensors tells the computer the air pump is not working. if it detected the pump being unpluged, it would throw the code everytime you started your car <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
p.s. i threw the code again this morning. and the three times i have thrown the code was while the car was moving.
Old Jan 29, 2003 | 10:55 AM
NicD's Avatar
7 Second Club
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by wrencher:
<strong> LS1 EDIT can delete ses light illumination on whatever codes are deleted. But you wont pass a readiness test (for emissions obd-II tests). </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I still do not understand why people say this. With EFILive you can look at the status of the readiness tests. All of mine pass everytime and I removed the EGR, rear O2s, and AIR system with LS1edit.
Old Jan 29, 2003 | 09:33 PM
FAST LS1's Avatar
p.s. i threw the code again this morning. and the three times i have thrown the code was while the car was moving. [/QB]</font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">On LS1.com they said the O2 Sensors didn't contribute to the code being thrown. I have O2 Sims in place of my back 2 O2 sensors since I have an ORY-pipe with my Headers. My friend and I think that by using the appropriate resistor in place of the pump we might be able to trick the computer into thinking it's still there. I don't have my Haynes manual with me here, but I'm going to look up what the 5 wires are going to the EGR pump and AIR pump. If I can just take it all out and slide in some 30 cent resistors, I'd much rather do that than spend $100-150 getting it programed out.
