Deleting AIR pump without throwing a code by using a simulator?
Old Jan 28, 2003 | 10:34 PM
FAST LS1's Avatar
Default Deleting AIR pump without throwing a code by using a simulator?
I was wondering what the computer checks to throw the code when you dissconnect the AIR pump? Is it just checking to see if the pump comes on and if there is a load, or do the O2 sensors play a part in the code being throw? If the computer just checks to see if the pump is working, I'm guessing you could make some kind of simulator like we have for our rear O2 sensors. The reason I ask this is because I would like to delete my AIR and EGR without having to get my ECU reprogramed and I don't have access to LS1Edit. Has anyone tried this?
<small>[ January 28, 2003, 10:37 PM: Message edited by: FAST LS1 ]</small>
Old Jan 29, 2003 | 09:39 PM
Snootch's Avatar
Default Re: Deleting AIR pump without throwing a code by using a simulator?
I dunno... Get a multimeter, and see what the resistance of the connector is on the pump, with the car running, and when off. Purchase a resistor from Radio Shack (1/2 or 1/4 Watt) and see if it works. kinda like the same thing you would do if you were doing the free CAGS elimination mod. I'm curious to see if it'll work too. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Old Jan 29, 2003 | 10:52 PM
Beeler422's Avatar
Back in the staging lane
I think you'll get more answers in the computer section. Moving over there.
Old Jan 30, 2003 | 12:20 AM
FAST LS1's Avatar
Ok, I found out that the O2 sensors do not contribute to the code being thrown. That means you should be able to use a resistor or something to make the computer think the pump is still there and working?
<small>[ January 29, 2003, 12:28 PM: Message edited by: FAST LS1 ]</small>
Old Jan 30, 2003 | 12:59 AM
MONGOOS's Avatar
I would be very interested in this too if anyone knows how it could be done?
Old Jan 31, 2003 | 10:33 AM
FAST LS1's Avatar
Since I posted in 2 places instead of asking to get the thread moved, I'll just combine the last thread,
https://ls1tech.com/ubb/ultimatebb.p...;f=23;t=003841
with this one.
I'm going to check the Helms manual this weekend and maybe put the multimeter on there to see what all the wires are for. I hope it's as simple as putting some resisitors inplace of the pump.
Old Jan 31, 2003 | 07:24 PM
TexassTA's Avatar
Keep us posted on this.I have been wondering why someone hasn`t figured out what resistor would work,like it does on the cags. Thanks
