LTFT +5 & +6 bad?
I am going to be installing MAC headers with carsound cats soon, so I am trying to get a baseline reading before I make any changes.
Thanks!
Tommy <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
I believe I read somewhere on here the stock cars LTRIMS come from the factory with like 0 to +4 or so readings?? Maybe I read it wrong though...
also i think headers usually richen the car so they should drop some after headers... again i could be wrong <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Should installing Mac headers cause the ltrims to go more toward the negative side, or just go higher on the positive side?
Thanks.
It would be interesting to know what the addition of headers does to your LTFTs by themselves.
It is my understanding that factory stock cars will run +4% to +6% on LTFTs, FWIW.
<strong> It is my understanding that factory stock cars will run +4% to +6% on LTFTs, FWIW. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i knew I heard that before <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<strong> Actually our cars come rich from the factory <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
Try and get your Lterms -1. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">ahh gotcha... i swore I saw something about them having slightly positive LTRIMS though..
but either way it is ideal to have them in the -4 or -3 range...
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Doc99SShome:
<strong> It is my understanding that factory stock cars will run +4% to +6% on LTFTs, FWIW. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">i knew I heard that before <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I get negative integers on the Collector. Got similar results on her previous car, a '01 WS6.
FWIW
I don't know . . . maybe the fact that I did both taps when each car had very little break-in miles affected the readings <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
<small>[ February 03, 2003, 05:11 PM: Message edited by: The Dragon ]</small>
<strong> My qestion is if iam at plus LTS+5-8 iam rich or lean? Or what if there -5-8? </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Technically, you are not rich or lean. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> The PCM is compensating, and its compensation is to shoot just a tad more fuel in than theorhetically calculated. So the engine is not running lean, the PCM is keeping it at stoich by 'learning'. However, the *trend* on a (+) LTRIM is that you are starting to run towards lean, but the PCM is compensating. If you start railing out the trims (like at +23 where it won't go any higher), THEN you are lean. But if you're within the 'moving' area of the trims, the PCM keeps you OK.
Remember, trims are a *compensating* factor. If your trims are moving around, that is *fine*. I personally like to see them slightly negative (PCM pulling fuel out slightly - aka PCM thinks it's running slightly rich). That's just my personal preference, based on my LT1 experiences. A few points on either side is nothing to make a fuss about. But if you see it getting out one way or the other (I'd say outside of +/- 10-15% or higher), you need to do some work.
-Andrew
EX.
if PCM is adding fuel during regular throttle (+LTRMs) then it will add a little more during WOT (causing it to be richer)
if PCM is subtracting fuel during regular throttle (-LTRMs) then is will take a little away during WOT (causing it to be leaner)
Thanks for all the insights!
If the LTerms are positive they get factored in to the WOT fueling, adding fuel, causing the car to run richer than your tune.
If the Lterms are negative they will be dismissed when the car goes WOT.
Just to give you an idea. LTerms of ~6 will drop the a/f from ~13.0 to ~12.4
Good Luck,
Kevin
