Air/Fuel Gauge install ?????
Old Feb 9, 2003 | 02:08 PM
tim99ws6's Avatar
Default Air/Fuel Gauge install ?????
i have a 1999 ws6 with LT's and o2 sims. i have wired everything else except for the purple wire, the actual wire that reads the air/fduel ratio. my question is what wire do i splice into to get the gauge to work, and where do i splice in at?????
any help would surely help, as i am basically done w/ the install, and this sucks....
Thanks~!!!
Old Feb 10, 2003 | 09:56 PM
NightHawk's Avatar
Default Re: Air/Fuel Gauge install ?????
The purple wire from the gauge connects to the purple wire on the front o2 sensor. I used the driver's side on mine b/c it was easier to get to.
Old Feb 10, 2003 | 10:09 PM
mighty mex's Avatar
why do that???
get you a wire schematic and splice into any of the o2 wires (i.e driver side or pass. side your choice) behind the pcm. what i did when i installed mine was from the pillar i ran a wire down under the dash to the pass. side and through the grommet behind the glove box on the firewall. then i spliced the wire behind the pcm and you cant even see any wires. this way you dont have to worry about the hot exhaust melting the wires. just my .02
