Possible to raise AFR in closed loop?
Old Mar 10, 2006 | 06:47 AM
Doc's Avatar
Doc
I'm sorry guys but somebody has to say it. F & Y bodies = Performance
Hybrid, (spayed or neutered) =
Seriously, sounds like you need a beater to poot around. Sounds cheaper than risking a potential hazard.
Nice thread tho, good info.
Old Mar 10, 2006 | 08:54 AM
RedWS6 00's Avatar
Had an emisions test, Passed on C02 and the hydrocarbons, but something called Lambda was out of range, ment to be between 1.000 and 1.090. That Toyota emmisions documents was interesting reading but what is Lambda? Does this mean my cats are dead? i think I been feeding them too much fuel after not a brilliant tune after incresing the injector sizes probably didn't help. Can the Lambda reading be fixed with new cats?
Old Mar 10, 2006 | 04:01 PM
fast98's Avatar
it is your exact a/f ratio. a lambda sensor is a wideband 02 sensor 1.0 is 14.7:1. less than 1.0 is rich and greater is lean. so take your number 1.09X14.7=16.023:1 air fuel ratio. get it
Old Mar 10, 2006 | 08:23 PM
mr2guru's Avatar
What tuning software do you have?
I know in HPtuners my lean cruise feature is enabled. Just plug the right numbers into the tables and it works great.
Old Mar 10, 2006 | 08:36 PM
joecar's Avatar
Originally Posted by RedWS6 00
... but what is Lambda?
lambda = 1/EQ = AFR/STOICH
or
1/lambda = EQ = STOICH/AFR
rich: lambda < 1 or EQ > 1
lean: lambda > 1 or EQ < 1
For gasoline/petrol, STOICH is 14.63 air-to-fuel.
Old Mar 10, 2006 | 08:58 PM
muncie21's Avatar
That would be interesting to see. I heard the American ECUs had this feature disabled in the machine code
Old Mar 10, 2006 | 10:41 PM
02BlackOnBlackSS's Avatar
Lean Cruise works for GTO's.
Old Mar 10, 2006 | 11:00 PM
muncie21's Avatar
Hmmm must be the aussie heritage
