How to set up MAFT
Although you won't be able to get as close with an MAFT when compared to Edit, you should be able to get it around ~-3 which is fine.
Try to do your Lterm taps cruising around town and not on the highway.
Once this is complete, do a WOT and make sure your Lterms go to 0. Then you can adjust the WOT switch on your MAFT to richen or lean up your mixture as needed.
Since the factory O2's aren't accurate, a 12.5 - 13.1 A/F could read anywhere from .810 to .950 on your O2 averages at WOT. A suggestion would be to lean it out until you get knock, then richen it one notch <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<strong> A suggestion would be to lean it out until you get knock, then richen it one notch <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I'm doing headers soon also. Would the knock be at WOT. As of right now I'll just have the dyno with wide band 02. Will I just hear the knock, or would I have to be using Autotap to know when I get knock? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
http://www.ramchargers.com/RamNews/Translator/index.htm
