Somebody explain the theory behind...
Old Feb 11, 2003 | 05:10 PM
BlueWheels's Avatar
Default Somebody explain the theory behind...
The reasoning behing adjusting your L-Terms for part throttle? I recently purchased LS1 Edit, borrowed a wideband O2 box and hit the streets. While my WOT needed some work, I had a PERFECT 14.7 all over the throttle range otherwise. During this time, my L-Terms moved between -5% to 5%, but the O2s and the computer were doing their job, keeping the A/F ratio at 14.7. Considering that this is probably the case in most applications (as long as your O2s are working), why would you even mess with programming for part throttle???? It doesn't make sense to me..
